Quantify impact of a fix
  • 19 October 2022
  • 92 views
Userlevel 1
Badge +1
Hello!
Is there a way to quantify the impact of a fix release on a set of charts? I am aware of the release annotation functionality, but I am looking for a functionality that would provide more insights in a chart view.
Something like, since release of this fix, we’ve seen metric X increase by Y percent.
Thanks,
Abdul
Best answer by Saish Redkar 19 October 2022, 22:44
Thanks for reaching out here! Would you be able to share more context about what you’re hoping to achieve? The first thing that comes to mind that the team shared with me is to check out the impact analysis chart detailed here. Retention also has changed over time, and funnel conversion has over time. Here are more docs, for reference:
https://help.amplitude.com/hc/en-us/articles/360050153551/#retention-vs-change-over-time
https://help.amplitude.com/hc/en-us/articles/360053338671#h_53d4a5f9-224a-4841-b0bc-c1387e279108
You can set up a time with our value engineering team as an enterprise customer through your success contact.
Hey @aalqaroot
If you are using the native releases functionality, then you can check out Releases Report which allows for some metrics /charts. I haven’t used it myself so can’t elaborate more on that.
Another approach would be to use the charts mentioned by Jeremie in a custom dashboard and see the changes by having the release version as a dashboard parameter.
I’m not aware of anything out there which can be a more automated way of giving out specific change insights.
