Post-group analysis on event attributes&filter event
  • 31 March 2022
  • 103 views
Userlevel 1
Badge +2
We have an event whose property is the playback duration, we want to group the playback duration according to 0-5, 5-10, how can I do this?
And We want to get the data with the largest event attribute value for each user for analysis?how can I do this?
Best answer by Saish Redkar 31 March 2022, 17:06
Hey @xiaomeng.zhang
The property value distribution metric in the event segmentation chart will help you bucket your duration.
Similar to this chart.
The max value per user is a tricky one. You can refer to this post and try replicating that-
Thank you @Saish Redkar 😀
