Links on the new domain app.amplitude.com are not generating previews in slack.
Best answer by Anthony
View originalLinks on the new domain app.amplitude.com are not generating previews in slack.
View originalHi
You can Disconnect and Reconnect the Slack integration under your Profile and it should get fixed. Although the unfurling speed has been slower than the previous url format.
I removed the integration and am trying to re-add it, but it seems that it will not re-integrate.
Result: Taken to this page https://app.amplitude.com/analytics/play2pay/home
Return to slack App Store and note that “Add to Slack” is still visible and links still not unfurling.
I tried clicking Yes, Please but it just goes to the “Add to Slack” page above.
me too!
Ah okay. I thought you meant in my slack profile
Thanks.
I’m an Admin of my org account and disconnecting and reconnecting Slack via this helped solve the issue. Let me know if that works out for you.
