Guessing this should be obvious but I can’t figure it out. I’m trying to plot the event count and the median of an event property on the same chart. Is there a way to do this?
Best answer by Saish Redkar
View originalGuessing this should be obvious but I can’t figure it out. I’m trying to plot the event count and the median of an event property on the same chart. Is there a way to do this?
View originalHi
You can try using custom formulas to chart out 2 different metrics in the same chart for most of the cases.
Here’s a demo chart using 2 custom formulas - https://app.amplitude.com/analytics/demo/chart/new/64a7yily
Thanks, appreciate the reply. But as far as I can tell, custom formulas don’t support median, right?
Yes, there isn’t a direct custom formula for median in there. You can try using PERCENTILE(A, 0.5) to get close to the median.
Ah, haven’t noticed PERCENTILE. Thanks!
