Is possible to concatenate event + properties?
  • 12 December 2022
  • 173 views
Hey all, I’m needing help with something I cannot create
I have this example:
standar_event_1 & standar_event_2
Properties (same for both):
client_id
user_id
I’m trying to create an unique event by concatenating the event and the other two properties without success for each event, to later calculate the conversion from standar_event_1 to standar_event_2.
Is this possible somehow?
Thanks in advance
Best answer by Saish Redkar 12 December 2022, 21:05
hey @Gustavo
I’m not sure if I completely understood your use case here.
Here are some approaches you can read up on and see if either of those are helpful -
hey @Saish Redkar , thanks for replying!
Sorry if I wasn’t clear.
What I want is to create an unique event using the event + two properties I have.
Concatenate of:
Event A | Property 1 | Property 2 = Event 1 (unique)
I have multiple Event A today, and my numbers are inaccurate since I have duplicate values if I only count the Event A. If I could somehow concatenate with the properties I would be able to create an unique value.
Lmk if I am not being clear enough please and thanks a lot for your help :)
Thanks for elaborating @Gustavo
I think the Merge Events/properties from Transformations could work here. Do note that this is only available as part of the Govern Add-On.
Userlevel 2
Badge +5
Hi Gustavo!
I wanted to add that a Custom Event may also work for you if include where clauses for more specificity. This is useful when you want to use an “or” clause in the events module.
I hope this helps!
Loc
