Hi everyone,
I am on a free tier and trying to find Median session per user for my iOS and Android apps. Is it even possible?
The closes I got was using the Median of property value but I doubt that is the right thing.
Hi everyone,
Hi
For session related metrics, the Sessions Chart will be the best way instead of the event seg chart.
Here’s a demo chart -https://app.amplitude.com/analytics/demo/chart/new/lt0e25fj
You can measure a bunch of metrics in here
The median of any of the above metrics can then be seen in the table breakdown
Thank you
I tried what you suggested but I don’t think it solves my issue.
The sessions are still counted by Average per user and Row Median only applies to the rows which contain average sessions.
I am trying to count Median sessions per user. Some users using apps 1 time, the other use 55 times, the average would not be as accurate as I need in that case.
Sincerely,
Victoria
