Hello,
I’m trying to do an analysis on one event. For example, Add Item to Card and Group By ‘Age’.
The issue I’m having is that I have a lot of Age values from 18 to 60 so something around 42 unique values. Which makes the analysis very hard.
Is there a way to group the values by buckets for example 18-25 25-35 35-45 … ? So the analysis would be easier ?
Thanks a lot,
Matthias
Hey @matthiasr
You can leverage the Properties metric and measure the Age property using the Distribution of Property Value option with custom interval sizes. Something like this .
Thanks a lot !
If you need more control over the different bin sizes, this kind of approach is also possible, although a bit wieldy.
