Hello,
i’ve integrate my app with Amplitude and he works fine, build app and send events, all its OK.
But, my problem is when i try generate the appbundle (.aab) of my application with command flutter build appbundle.
The problem was started when i installed the pub flutter_amplitude, i try install all versions, but the problem persists.
If i remove the amplitude, i can generate the appbundle without problems.
The error showed on the terminal is:
Gradle build failed to produce an .aab file. It's likely that this file was generated under C:\dev\myapp\build, but the tool couldn't find it.
I’m using:
Flutter: 2.5.3
Dart version 2.14.4
Anyone can help me, please? Thanks!!
Best answer by allanthomasof
