Hey, I’ve created 5 dashboards and now I’m not able see the option to create a 6th one. Just curious to know if a user is only allowed to create five dashboard. If not, can someone help me with this?
Thank you
Thank you
Hey
There is no limit for the number of dashboards you can create in Amplitude.
If my guess is correct, the slight UI change could be the reason you missed the new dashboard create option under the Report option?
If not this, then it could be a UI bug that you encountered.
Thanks a lot for the reply, just figured out how to add more dashboard. Yeah, there was a slight UI bug some time back. But it's back to normal now.
Have a great day
