Greetings,
The ticket is related to the previous ticket: link, which you marked as SOLVED without responding there. Though I never mentioned the issue is resolved, please kindly help me further:
Let me describe the issue again:
In genera,l I have two events:
- event A
- event B
1) Event A has the "spend" property, I will have to use this property value in the formula.
2) In Event B I would need to use the number of unique UNIQUES(B) calls - this is clear.
I need to have a sum of values of event A for the last 7 days within 180 days. I found the CUMSUM() formula which does almost everything I need, but I cannot set up a number of days for which I want to get a sum of values. Logically, the formula should look like this:
CUMSUM(PROPSUM, A, 7)/CUMSUM(UNIQUES, B)
I need to select 180 days on the chart: https://prnt.sc/oKAwqbOI5rmI.
But I am getting 400 error: status code. I understand that the CUMSUM() formula does not support the third parameter (7 days). But maybe there's another way to achieve the result?
Please share more information
Thank you
