Create alerts to send during a specific time period
  • 22 February 2024
  • 57 views
Is there a way to setup alerts to only send at a specific time. I only want to receive alerts from 6am-10pm.
Best answer by Saish Redkar 22 February 2024, 17:53
HI @Ashay Jain
Are you referring to alerts from a individual chart via alert monitoring?
If yes,then I don’t think you can set any specific time since alerts will be triggered whenever your alert condition gets triggered.
However, if you are referring to dashboard reports subscriptions, then you have the ability to control what time and day you want those recurring reports.
Thanks Saish for responding back. I am referring to alerts from an individual chart via alert monitoring.
I was trying to restrict alerts from 6am-10pm as my alerts were not statistically significant during night time.
Yea, don’t think that’s possible for now. Maybe you can key in a more restrictive condition trigger on your alert settings to achieve statistical significance.
Per their docs - This email will be sent by 8:00 AM in the project's timezone for daily metrics, or the hour after an anomaly if an hourly metric is detected.
