I have an event with multiple properties and want to be able to graph the daily average of a formula that includes both of those events. To be specific, I have an event that has a shoppingTimeInSeconds property and a numberOfUnits property. I want a graph that charts the daily average of this units per hour formula:
3600.00 / (shoppingTimeInSeconds / numberOfUnits)
I have not been able to find a way of accomplishing this other than by sending a unitsPerHour property along with the event that is already calculated before being sent to Amplitude.
Hi Michael,
There is a Formula Metric view in the event segmentation chart which will let you create custom formulas to analyze the event properties that belong to the same event. Here’s a link to the help center article with more details on custom formulas.
If you are using numerical properties only and you want to see the average, I can also suggest the Properties Metric view and the dropdown for “average of property value”. I don’t want to share any of your account-specific information here in the community forums, so I made an example chart using AmpliTunes demo data. Just imagine your data in place of the 2 events on the left.
Chart linkhttps://analytics.amplitude.com/demo/chart/new/y9fnnju
I set this to the hourly view and the takeaway on the right side of the chart to “Average Value” (using the 3 dots for “more”).
To find your unitsPerHour metric, I think you can divide the two averages. It would be the average of TimeInSeconds divided by the average of numberOfUnits
Let me know if you have questions! Thanks! ​​​​​​​
Loc
Hi @Loc Tran. I’ve looked over your response and I don’t think it answers my question…
I am aware of the Formula Metric view in the event segmentation chart, but I don’t see a way of achieving what I outlined. I am also aware of the Properties Metric view that allows you to see the “average of property value”, which is why in my original post I said “I have not been able to find a way of accomplishing this other than by sending a unitsPerHour property along with the event that is already calculated before being sent to Amplitude.”
Towards the end of your response, you said that you’re not sure but you think I can divide the two averages of the “TimeInSeconds” property and the “numberOfUnits” property. This is true, but it does not answer my question or solve my problem. I need Amplitude to calculate the unitsPerHour of each event and then graph the daily average of those calculations. Is this possible?
Hi Michael,
Thanks for your reply! The best way to track the units per hour would be to send the calculated property to Amplitude. I tried playing around with the formulas chart in demo data, but the group by properties don’t work the same as your use-case. I hope you can get the idea though!
Chart link: https://analytics.amplitude.com/demo/chart/new/6t1h3hs
So I’m taking the “duration” event property and turning it into hours. Then, I copied the same event and grouped by a different property. Divide it by # of hours and it should give units per hour with your data.
Loc
