Any order between two events in funnel analysis
  • 16 February 2024
  • 66 views
Hello,
I’m currently trying to make an amplitude chart that shows the conversion % between event A and event B. I would like it to consider A to B and B to A at the same time, while also not considering A to A and B to B. I was hoping that the “any order” function would work, but that doesn’t seem to be the case. Would there be a way to present the conversion in the way I listed?
Best answer by williamnewton 19 February 2024, 16:09
What an interesting question!! You can do a double ‘comparison’ and then un-select A>A and B>B.
Here’s an example funnel for you : https://app.amplitude.com/analytics/demo/chart/new/ms9ag1uj?source=copy+url
Hope this helps :)
Thanks for the help! This is exactly what I was looking for
