Additional best practices charts
  • 27 December 2022
  • 94 views
Amplitude have this template charts - best practices
Which additional graphs you would add to these best practices?
Best answer by Loc Tran 6 January 2023, 17:32
Userlevel 2
Badge +5
Hi @Nate
Glad to help! Can you clarify your question? Do you want to know if there are more graphs that can be added to a starter template?
Thanks,
Loc
Hey @Loc Tran
Nope :)
What i mean if there are any additional best practices graphs/chart besides the ones that in the templates.
Is it clearer now?
Userlevel 2
Badge +5
Hi @Nate
Thanks for your reply. The starter template gallery is a great guide to make your first reports. You can customize them to your needs, and perhaps this template guide can help you choose. Some suggestions are Amplitude new user onboarding, A/B testing, and Releases.
But in regards to additional best practices, its just these 5 templates and then articles in the Help Center.
Loc
