Question
In React Native Android app has issue with gradle 8.2.1
  • 16 May 2024
  • 263 views
Hi
I am using amplitude react native latest sdk @amplitude/analytics-react-native in react native. It is working fine with iOS, but when i try to build with Android, it is return error like as below:
A problem occurred configuring project ':amplitude_analytics-react-native'.
> defaultConfig contains custom BuildConfig fields, but the feature is disabled.
  To enable the feature, add the following to your module-level build.gradle:
  `android.buildFeatures.buildConfig true`
Can you guys suggest how we can resolve that issue?
Here, I tried to add this buildConfig flag but the issue is still there.
Thanks
We have the same issue, have to hack into the library and add
android {
buildFeatures {
buildConfig true
in node_modules/@amplitude/analytics-react-native/android/build.gradle
the error was gone, but got new issue reported
* What went wrong:
A problem occurred configuring project ':app'.
> compileSdkVersion is not specified. Please add it to build.gradle
Still struggling, really can use someone’s help here.
Thanks
The gradle version we are using is 8.5, React Native is 0.74.3
android {
buildFeatures {
buildConfig true
* What went wrong:
Thanks
have you been able to solve this issue? im stuck with the same error
