Question
Does anyone have any experience using Amplitude Experiment and Google Tag Manager together?
  • 22 January 2024
  • 112 views
Our goal is to have Amplitude Experiment set-up like a typical client side tool since it would be difficult to integrate our servers-side code due to some vendor issues. (long-term addressable, but not in the near term)
So the basic thought is
1> Fire Amplitude Analytics in GTM with the  “Amplitude Analytics Browser SDK” GTM community template.
2> Fire a script tag to initialize the Expierment.
 <script src=“https://unpkg.com/@amplitude/experiment-js-client@1.9.0/dist/experiment.umd.js”></script>
3> Create a Google Tag Manager Variable which is a custom javascript variable and captures which the experiments and variations the visitor is in.
4> Use those values in the GTM variables to execute or not, the code in our experiments.
This is not pretty.  But I haven’t come across much content on Amplitude Experiment, since it is a newer product and not for the lower tier plans.
any feedback would be appreciated.
Badge +1
Hi @Michael McNicholas
I'm trying the exact same.
We use the Amplitude Analytics Browser SDK” GTM community template, and now want to also use Experiment via a Custom HTML. I have tried with this code, that are loaded after Amplitude Browser SDK.
(Got some help from ChatGPT...)
<script src="https://unpkg.com/@amplitude/experiment-js-client@1.9.0/dist/experiment.umd.js"></script>
<script>
// Initialize the experiment client with your deployment key
var experiment = Experiment.Experiment.initializeWithAmplitudeAnalytics('YOUR_DEPLOYMENT_KEY');
// Start the SDK and wait for it to be ready
experiment.start().then(function() {
// Once the SDK is ready, check the feature flag variant
var variant = experiment.variant('YOUR_FLAG_KEY');
if (variant.value === 'on') {
// Code to execute if the flag is on
} else {
// Code to execute if the flag is off
</script>
I have now tried this. The script is loaded but i get a 401, and the consol says “Missing Api-Key in Authorization header”.
I have double checked the deployment API-key, and the flag_key.
Would be interesting to also hear from others what the best practice is for GTM implementation.
What ended up working for me… is to chain the GTM calls - i.e. “Fire a tag after this one fires”
So the Amplitude Analytics Browser SD fires in one tag,
then the Experiment ones fires in a second tag (calling https://unpkg.com/@amplitude/experiment-js-client@1.9.0/dist/experiment.umd.js
Then I initalize the initialize the experiment object (since I know the previous tag has fired)
in a third tag
then I run the code for a specific experiment, get variations, etc in the fourth tag. And I am sure each part of the experiment code only runs when the part before it has been called.
…Otherwise, there might be a race condition where the second and later lines in the tag are running before the first part is complete.  Hope this helps.
