Android device blocked from sending events to Amplitude
  • 3 March 2023
  • 194 views
Userlevel 3
Badge +2
I think my specific Android device, which has our Android app with the Amplitude Android SDK, is being blocked from sending any events to Amplitude. How can I check that?
Best answer by Amplitude Admin 6 March 2023, 09:42
Thanks for reaching out here @Anthony If you're able to determine your IP address you can use Data Filters see if events are blocked from that IP address. This thread from your Community peers is also a good one to review.
Userlevel 3
Badge +2
Thanks. We’re not manually blocking/filtering anyone, but I thought I used to be able to see users auto-blocked by Amplitude (not by us) e.g., for abuse/misuse of the Android SDK back before the UI change, but I can’t figure out how to navigate to the page showing those users.
Hi @Anthony Just checking in. Were you able to make progress here?
