Events not showing in Analytics
  • 26 September 2022
  • 175 views
I am having an issue where my events show in the user feed but do not show or appear in the segmentation events option. It’s been about 4 days + since the event was created. So I am unable to
Best answer by Nehita I. 28 September 2022, 14:17
It shows up here and in the user log but not in the segmentation of analytics. See second screen shot.
Userlevel 3
Badge +5
Hi @ErnestSeniorPM ,
This is Nehita from Amplitude Support, thanks for writing in to the Amplitude Community!
I’m sorry to hear that you’re experiencing an issue with your events not showing, I will have to take a further look into this to better understand what may be causing the issue. For privacy purposes, I will contact you in a separate email to further investigate this!
Nehita
