Delete duplicated event properties
  • 22 June 2022
  • 138 views
Hi all!
We recently changed the event properties taxonomy from title to lowercase. We now have duplicated properties in the new events. I have admin rights and I know I should be seeing a “delete” option, however I see it for other events but not for the ones I actually want to delete! Any clue how to remove the title case event properties? Thanks!
Best answer by LauMD 23 June 2022, 10:27
HI @LauMD ,
Can you PM me your Org ID, Project ID and Org URL? I can then look into this for you and see but it might be a bug!
Someone from your team checked this for me and it works now :) Thanks for the prompt reply!
