How to hide the 'Amplitude Events'?
  • 2 April 2024
  • 95 views
Hi, in User look-up menu, to many 'Amplitude Events' are make unclear the timeline, so it’s too hard to seperate ‘User made events’ and 'Amplitude Events'.
How can I hide the 'Amplitude Events' from User look-up timeline?
You can choose to hide these events using the visibility status in Data. This action will allow the events to be hidden from the following
However, these would still be visible in your raw event data/ user lookup afaik.
Hi Jiung,
It's not possible to hide Amplitude Events from the user timeline. However, you can customize the events you want to see in the event stream by choosing to show all events, highlight specific events, or only show specific events.
Hope this helps, and please let me know if you have any questions.
Best regards,
Thao
