I am not sure which chart type to use here, given the two events would be logged for two different users:
- invite event is sent by user A
- accept invite is received by new user B
Hi
You will have to capture either the user_id ( of the user who invited ) or some sort of invitation_id as event properties on both the events - invitation sent and invitation accepted.
To measure conversion i.e. of all invites sent how many got accepted, you then use the Funnel chart by holding any of those event properties constant.
However, the two events are associated with two different user ids. Is there a way to link two such events in a funnel chart?
Ah, yes. My bad, for funnel analysis, each event must be performed by the same user id.
One approach would be to generate an Invitation Received event for the user who got invited alongside the Invitation Sent event . So on the user level, funnel will be invitation received --> invitation accepted. But this can be a bit tricky to implement sometimes since in most of the implementations out there a user id can be only created after user accepts an invite.
Here’s a post which addresses a similar scenario:
