HTTP V2 API "Connection reset by peer" error
  • 7 March 2023
  • 185 views
There is no problem with the event sent to Braze (have the same structure), but the “Connection reset by peer” error occurs only in the event sent to Amplitude. (Occurs in about 5%) Since we are not using a separate proxy, there is no path for the error to occur on our side. What could be the cause?
Thanks for sharing this notification @neo We’ll take a closer look and get back to you.
Quick update here @neo. Our Engineering team is taking a closer look and we’ll closer the loop ever email with an update when it’s available.
