How to delete a chart in amplitude?
  • 6 August 2021
  • 6 replies
  • 1160 views
Userlevel 1
Badge +1
After creating a chart, how could I delete it?
Best answer by Saish Redkar 6 August 2021, 20:46
Hey @Bill
Currently there isn’t a direct way to delete a chart in Amplitude.
The workflow will be to archive the chart first and then delete it.
To do this ,
  1. you will first have to navigate to the “More” Tab over the chart -
  1. Archive the chart
  2. Once you Archive it, you will get the following pop up message
  3. Once the chart is archived, the delete option will be enabled for the chart
  1.  Hit Delete and once you say yes to the deletion modal message, the chart will be deleted.
Userlevel 1
Badge +1
Thanks Saish for the quick turn around.
P.S. You can only perform the above workflow on a saved chart.
If you are trying to delete a chart draft ( unsaved chart ) you can directly do it from
My Workspace → Chart Drafts
Userlevel 1
Badge +1
Hi Saish,
Is there a location storing all the archived charts?
Bill
There isn’t a dedicated area in the Workspace for archived charts yet ( could be a potential feature request ).
But you can filter and search your archived objects in the Search Bar.
Userlevel 1
Badge +1
Well explained, thanks Saish...:thumbsup:
