After creating a chart, how could I delete it?
Best answer by Saish Redkar
View originalAfter creating a chart, how could I delete it?
View originalHey
Currently there isn’t a direct way to delete a chart in Amplitude.
The workflow will be to archive the chart first and then delete it.
To do this ,
P.S. You can only perform the above workflow on a saved chart.
If you are trying to delete a chart draft ( unsaved chart ) you can directly do it from
My Workspace → Chart Drafts
There isn’t a dedicated area in the Workspace for archived charts yet ( could be a potential feature request ).
But you can filter and search your archived objects in the Search Bar.
