Grouping funnel by event properties
  • 8 October 2021
  • 309 views
Userlevel 1
I have funnel that is based on users starting a piece of content (Event A) and users finishing a piece of content (Event B).
I’d like to breakdown the funnel by an event property (content topic) so that I can compare the conversion rate of users when they engage with Topic Y vs. Topic Z but it doesn’t seem like I’m able to do this?
Best answer by Saish Redkar 8 October 2021, 18:38
Hey @patrick.conneely
If I’m understanding your question correctly, then you can use the “broken down by” clause to the applicable step in your funnel setup as shown here.
Badge +5
Hey Patrick,
Saish is absolutely correct with the answer and the provided link! Just to give you a visual example, I have created a Funnel analysis with ‘broken down by step 1 Genre_Type’ using our Demo data.
I hope this helps.
Yuanyuan
Userlevel 1
Thanks both!
Obviously missing my coffee that day with that one as that’s pretty simple!
