Can I offset 'Compare to past'?
  • 19 May 2021
  • 905 views
Userlevel 1
Hey Amplitude community,
I hope one of you have a solution to my issue here :D
Question
‘Compare to past’ lets me compare to the same n days to the previous year. This comparison is date by date.
As weekdays change each year, is it possible to offset this comparison, so I compare monday - friday with monday - friday previous year?
Context
I’m trying to make a performance dashboard, where I’ll compare sales performance with previous year. We want to compare weekdays instead of precise dates, as that is a better explaining factor for fluctuations.
Solutions I’ve tried so far
2 charts: current performance vs last year performance
  1. Current performance chart: daily view of last 7 days (May 12 - May 19)
  2. Last year performance chart: daily view of last 7 days, offset by 364 days
Issues
  • I can’t present performance in the same chart
  • Offset needs to be changed on leap year (I think)
‘Comparing to date range ending’ on custom date
  • Current date range: last 7 days (May 12 - May 19)
  • ‘Comparing to date range ending May 20’
Issues
  • I doubt custom end date moves as days go by. Only useable for the specific week (May 12 - May 19)
Optimal outcome
1 chart where I see 7 days compared to previous year, comparing the same weekdays.
Best answer by eddie.gaona 20 May 2021, 20:47
Badge +3
I’m 91,2% sure the custom end date moves forward as the days go by, so essentially it allows you to set the comparison period as you like. I’d at least give it a go.
I’m not sure how it interacts with leap years, though.
Hello @andreas_heden!
To my understanding, you want to plot M-F to the same M-F from the previous year regardless of dates changing. For example, March 8 can be a Friday one year and the next year a Saturday.
There is no out-of-the-box way to accomplish this dynamically. I can see how offset in the “compare to past” feature would help in this case and I can submit that as a feature request.
As you have already discovered using the “custom end date” would at this time be the best approach to get what you are looking for.
Userlevel 1
You’re right. The custom end date seems to be rolling (which essentially clears my problem).
@eddie.gaona it seems “custom end date” is the dynamic solution I’m looking for, so no need for submitting a feature request. Maybe add a description to “custom end date” so users know it’s a rolling date.
