Unique Users vs Total Events for any specific click event compared daily
  • 14 February 2024
  • 65 views
I have a click event - where I get different counts on Uniques (basically unique users doing that specific activity that day) and Event Totals (Total events for that specific activity that day). I want to draft a side-by-side comparison of the two values (uniques vs event totals) for the event over a period of time distributed daily.
I am new to amplitude, and unable to do the same - adding new events and making changes for that just duplicates that change across for all iterations of the event.
Best answer by Saish Redkar 14 February 2024, 18:19
Hi @Shubham Patel
You can do this using formulas . Here’s a demo chart for your use case - https://app.amplitude.com/analytics/demo/chart/new/l4s3877n
Hi @Shubham Patel
Hey Saish - this works. Thanks a ton.
