Communication between Segment and Amplitude.
  • 27 February 2023
  • 125 views
We have sent a property called "is_customer" to Segment, which can have a value of "true" or "false". However, some customers receive a value of "none" for this property. These same customers have the property correctly defined in the Mixpanel platform. We suspect that there may be an issue with communication between Segment and Amplitude. What can we do?
Best answer by Amplitude Admin 28 February 2023, 22:06
Thanks for posting here @anakaiser. Were you able to make progress? Here are a few helpful posts and more information about importing segment data in our Developer Docs. Let us know if you need additional help!
