Unable to sort based on custom event attributes.
  • 19 August 2023
  • 86 views
We are unable to apply filters to the custom event properties. Basically, we have an event named "checkout_init" with a custom event property called "checkout_type", which can take on values of 'old' or 'new'. Interestingly, I can observe the same event property seems to be fine in User Streams.
And This issue only arises in the production environment, the same event with event properties functions correctly in the sandbox environment.
Best answer by Saish Redkar 30 August 2023, 15:53
Hi @Kiran Kumar
Can you verify in your production project’s Amplitude Data if the checkout_type event property’s visibility is set to Visible ?
