Do you know why same event shows separately?
  • 7 June 2023
  • 89 views
Can events with the same event name be displayed separately in the event list?
In the code, it is set based on the same standard(also removed shortcutKind property in the code), but the event is divided into two according to the property value. (Mutually exclusive except kind = 'position')
Best answer by JennRu 7 June 2023, 14:59
Hi @Jayeon Choi from your screenshot of the data outputs, it looks like you might have queried the event jobs__shortcut__click two times in your event segmentation chart and each unique instance has a different set of group by conditions, which results in the 2 different columns of group by conditions
  • the first instance jobs__shortcut__click is grouped by “pagePath”, “screen”, “kind”, “shortcutKind”, and “Platform”
  • the second instance jobs__shortcut__click is only grouped on by the first 3 properties “pagePath”, “screen”, and “kind”
That is why the same event name is being displayed separately in the list. If you remove one of the events from your original query, it’ll only result in one column of group by conditions.
What are you looking to display in this chart? You can divide the event based on strict property conditions such as
  • only display  jobs__shortcut__click where “kind” = resumeList
  • and separately only display jobs__shortcut__click where “kind” = profile
As you start to add multiple group by conditions to your event, it might be easier to read the chart in the format of a horizontal bar chart visual, or in a data tables chart type.
