Destination Data
  • 9 December 2023
  • 77 views
How can we manage what data is passed on from Amplitude to a destination. Currently we see almost all data is passed on but we want to manage particularly what user properties are passed on.
How do we edit it so we change what user properties are passed through to the destination. It currently says events and users and I do not see an ability to control what we pass through.
Best answer by Saish Redkar 11 December 2023, 17:26
Hi @Zayyan Chowdhury
Afaik, the type of data that is sent to any Destination will be pre configured based on the integration rules and type of integration. e.g. sending data to a downstream CDP or Warehouse will need to have the full data - event data + user properties.
There could be some integrations out there which might need just cohort level data ( user_ids ) for integration.
So there isn’t much access control on what type of data you are sending in most cases.
