Creating a Cohort with multiple events
  • 28 July 2022
  • 101 views
Userlevel 1
Hi Community,
New user here :)
I’ve got a question, I want to create a cohort of users we call “manager” this can be identified by some events we have that only managers can do.
The thing is, if i want to create it, i need to select “event” + OR + “event” + OR and so on
I was wondering is there’s some kind of multiselect option so that i’d be able to pick all at once?
Best answer by Saish Redkar 28 July 2022, 18:57
Hey @Omriko
From what I’m understanding, you don’t want to create this cohort using the  ..or performed ____ clause between all your desired events, right?
Here are a couple of options I would try out -
  • Using the Event Name as a filter to the events you want to multiselect
  • Create a custom event for your relevant events and use this custom event in your cohort definition
Let me know if this helps.
Userlevel 1
Hey @Omriko
Wow!
Thank you very much!
@Saish Redkar , thx for the above but a question… Is it by design that when filtering on event name I can not use Custom events? They’re not listed and when entered freeform, they dont get evaluated it seems.  Any ideas?
