how many projects i can create under 1 account
  • 6 September 2022
  • 230 views
Userlevel 2
Badge +1
suppose if i buy a growth plan will i be able to create multiple projects? i am asking this because here is the situation
we have free account currently  and current project setup is kind of destroyed  ( i created more that 2000 event types ) [ i was unaware of that ]
now we have implemented correct way - less event types.., now my question is should i create new project to launch our newly implemented setup OR should i just delete event types and modify existing  one (wait is it possible ?)
Best answer by Saish Redkar 6 September 2022, 17:07
Hey @pawan
Afaik, there isn’t any limit on the number of projects that you can create under any specific plan.
Since historical data in Amplitude is immutable, you won’t be able to modify the already ingested data on the raw level. The best approach will be to create a new project in your account and start sending data via your newly implemented setup.
Userlevel 2
Badge +1
Thanks.
