Unifyuser ID with segments
  • 6 January 2023
  • 105 views
Hi.
We're having some troubles with unifying user ID with segments, amplitude and other tools Suppose a user fills up our typeform somewhere in discord, and we'd like to send the user's responses to amplitude, what should we set as User ID into segment/amplitude? Since this is a user who leaves the email as the only identifier, what should we set as User ID in segment/amplitude? How should we unify users in segment/amplitude, if one engages with other 3ed party tools and only leaves the email as the identifier?
Best answer by Jeremie Gluckman 18 January 2023, 22:42
Thanks for reaching out here @Alica. Please excuse the delay. Were you able to make progress? Here’s more information about the Amplitude - Segment integration in our developer center - link.  Please let us know if you need additional support.
Badge +7
Hey there Alica!
Happy to assist here! I recommend keeping your IDs consistent, so if you only have emails available - this might be your best choice to use emails as user identifyers both in Segment and Amplitude.
General practises on assigning user IDs in Amplitude can be found here
Hope this helps to move in the right direction :)
Zhenia
Thank you @Zhenia Semenina! 😁
