Question
Not able to filter by an event properties
  • 11 December 2023
  • 6 replies
  • 122 views
Hi :)
I can't find an event property called "Benefit_Button_Type" anywhere. We created the same way as the others events that I have, but I cant filter it in data>properties and neither in the dashboards.
The strange thing is that I know it exists because I can see it in all the user streams (image).
Can you please advise on this case? Thank you.
Hi @Tere Cox
Can you set the filter to “Any Status” and see if your desired property is showing? If this new property is showing as “Unexpected”, you might need to add it to the tracking plan first to start querying in charts. You also need to check if by any chance the visibility status of this property is set to hidden or not.
@Saish Redkar Thanks for the advice!
But i'm still having the same problem… I cant find what is happening 😢
Here I set de filter to “Any Status” but cant find it, look:
What could be happening?
Thankss
So it’s neither showing as “unexpected” nor “hidden” under the Data filters.
The only other check would be to verify if that ingested property is in the same project as the one you are looking the Data Properties OR the classic Amplitude ingestion ↔ UI visibility delay.
How do I check that?
@Saish Redkar Thanks for your anserw :)
Hi @Tere Cox
Were you able to find that property in your tracking plan?
