I’m attempting to block certain IPs however using the drop filter doesn’t seem to work as the numbers stay the same even with the filter applied.
Best answer by jmagg
View originalI’m attempting to block certain IPs however using the drop filter doesn’t seem to work as the numbers stay the same even with the filter applied.
View originalHi
