Question
Property QA and Data Governance
  • 17 October 2023
  • 0 replies
  • 67 views
Userlevel 1
Badge +1
Hello,
We implemented using the SDK and want to clean up our events and properties as much as possible. We turned on the naming convention dropdown from the % of 100 your data scores.
There are properties being grayed out because they don’t follow snake_case. However some properties are older ones that are no longer in our SDK tag. They share properties so I don't want to delete them or it will not apply to the other event.
Question is, is how do we detach the property from the event in Amplitude without deleting it? I suspect this doesn’t exist yet in the User Interface but want to make sure we aren’t missing anything.
Marianne
Be the first to reply!
