Is there a way to bulk move events
  • 11 July 2023
  • 83 views
I’m new to using Amplitude and I’m currently creating event properties in Amplitude. Accidently there’s 32 event properties created in the wrong project, is there a way I can bulk move these events to the right project?
Best answer by Saish Redkar 11 July 2023, 17:56
Hey @sdio0002
Data ingested in Amplitude is immutable on the raw level. Currently there is no support to migrate events from one project to another in case of such data discrepancies.
The most common direct approach is to export your data from project 1, clean/transform the properties accordingly and re ingest in your correct project. You will need to block these properties from the wrong project and hide them from the chart dropdowns using Data.
Got it. Thank you Saish!
