How to stop accepting events temporarily for a project
  • 23 October 2023
  • 80 views
I want to stop accepting new events for time being for one project in amplitude . how can i do that?
Best answer by Saish Redkar 23 October 2023, 14:47
Hi @Narendra Balaga
You can try blocking those events in your project - https://help.amplitude.com/hc/en-us/articles/360059279291-FAQ-The-difference-between-hiding-blocking-and-deleting-an-event-or-property
I don’t think there is a way to generalize “new events”, but you will have to block them individually by their event name.
if there are 1000 events in a project blocking each of them is difficult for time being if there is a way block the project accepting any event it would be better.
