Top events following an event
  • 13 September 2023
  • 81 views
I wanted to know how I can find the top events following an event.
For example:
Let’s say I have Event1, Event2...upto Event10. If a user clicks on a menu item, triggering Event1, I want to find out the top actions after triggering Event1, and want to show that by totals. So basically finding out the top actions that are performed on any particular page on the platform.
Please let me know if you know how do this, thanks a lot!
Best answer by Saish Redkar 13 September 2023, 11:18
Hi @Dhruv Tewari
You can use the Pathfinder Users chart for analyzing this.
