Got a question: found some bug while doing data tables with filter. When I am doing the filtration, Amplitude shows users that do not fall under stated filters. What might be a problem in such case?
Hey Yuliana Turchyn
Are you filtering on an user property?
Most likely that user’s current value for the selected user property could be different than the value reported during the chart interval. This makes the user get filtered on both those property values if they have reported different values across the time interval, which is a common behavior in an event seg chart.
Hey Saish Redkar,
The user’s property I am filtering on is unique, it cannot be changed across the time interval
Saish Redkar I have the same situation, if this is the case, do we need to change anything related to time? I’m in a Data Table view using an Event Property. Thank you!
Hi everyone, We're using Amplitude's S3 export and noticed that for every export batch, two files are created in our bucket: 1. A `_complete` file (0 bytes, seems to be a flag/marker) 2. A `.json.gz` file (the actual event data) The actual data lives entirely in the `.json.gz` file, so the `_complete` file doesn't seem to…
Hello, We have a blank screen after adding in Amplitude/Session replay into our app, it seems like some windows appear for a breif second before dissapearing back to the black screen. Currently are app is NOT using Jetpack compose. This is on a samsung active 3,
Hi, I set integration between Amplitude and Appsflyer(V1) - I see that integration is active but when I'm trying to check this integration in Amplitude section “Connect AppsFlyer” on the second step I see “Listening..” and nothing happend. Does this second step show any activity only if I begin sending events from…
I want to be able to identify and track the users that are hitting a specific page (feature) that is limited by our product tiering in our multi-tenant SaaS app. Our customer businesses have their own segmented dashboard based on the subdomain of the app url (somebusiness.ourapp.com), and I have figured out how to capture…
Hi there, I'm trying to integrate the surveys for react native feature to our app. I've followed the guide and I verify the plugin is "booted" correctly (right user id and device id) but when opening a link, while the linking handlers are correctly triggered, the call to handleURL is returning false - I've verified the url…
