The Identify API has a documented operation for removing items from an array property, but the Group Identify API doc doesn’t include such a method. Is that a documentation error or is it in fact not available?
michael.kuhl Apologies for missing that piece, but yes $remove is supported as well.
Thanks for posting here michael.kuhl I’ll share this with the team and circle back.
michael.kuhl Thanks for letting us know! The Group Identify API doc is missing documentation for the $preInsert and $postInsert operations, but these methods are supported for the Group Identify API.
Will submit a request to our team to have this updated!
To clarify: The $remove operation is not supported for Group identify?
$remove
Hi everyone, We're using Amplitude's S3 export and noticed that for every export batch, two files are created in our bucket: 1. A `_complete` file (0 bytes, seems to be a flag/marker) 2. A `.json.gz` file (the actual event data) The actual data lives entirely in the `.json.gz` file, so the `_complete` file doesn't seem to…
Hello, We have a blank screen after adding in Amplitude/Session replay into our app, it seems like some windows appear for a breif second before dissapearing back to the black screen. Currently are app is NOT using Jetpack compose. This is on a samsung active 3,
Hi, I set integration between Amplitude and Appsflyer(V1) - I see that integration is active but when I'm trying to check this integration in Amplitude section “Connect AppsFlyer” on the second step I see “Listening..” and nothing happend. Does this second step show any activity only if I begin sending events from…
I want to be able to identify and track the users that are hitting a specific page (feature) that is limited by our product tiering in our multi-tenant SaaS app. Our customer businesses have their own segmented dashboard based on the subdomain of the app url (somebusiness.ourapp.com), and I have figured out how to capture…
Hi there, I'm trying to integrate the surveys for react native feature to our app. I've followed the guide and I verify the plugin is "booted" correctly (right user id and device id) but when opening a link, while the linking handlers are correctly triggered, the call to handleURL is returning false - I've verified the url…
