Hello!
I have a problem in Amplitude. We have user for whom on ios events are not tracked
And also some other user for whom client events are partly not tracked
Most of these users are on ios. What might be the possible problem?
Hi Vadim Kvachev,
Thanks for writing this post!
When it comes to misisng events for users, I would suggest first checking if these events are deleted or blocked in Data.Please also check if you have block filter or drop filter that filters out specific events.
For users whose client-side events are not tracked at all, please check if it is possible that these client-side events are sent to a different user profile.
I hope this can help get the investigation started.
Hi everyone, We're using Amplitude's S3 export and noticed that for every export batch, two files are created in our bucket: 1. A `_complete` file (0 bytes, seems to be a flag/marker) 2. A `.json.gz` file (the actual event data) The actual data lives entirely in the `.json.gz` file, so the `_complete` file doesn't seem to…
Hello, We have a blank screen after adding in Amplitude/Session replay into our app, it seems like some windows appear for a breif second before dissapearing back to the black screen. Currently are app is NOT using Jetpack compose. This is on a samsung active 3,
Hi, I set integration between Amplitude and Appsflyer(V1) - I see that integration is active but when I'm trying to check this integration in Amplitude section “Connect AppsFlyer” on the second step I see “Listening..” and nothing happend. Does this second step show any activity only if I begin sending events from…
I want to be able to identify and track the users that are hitting a specific page (feature) that is limited by our product tiering in our multi-tenant SaaS app. Our customer businesses have their own segmented dashboard based on the subdomain of the app url (somebusiness.ourapp.com), and I have figured out how to capture…
Hi there, I'm trying to integrate the surveys for react native feature to our app. I've followed the guide and I verify the plugin is "booted" correctly (right user id and device id) but when opening a link, while the linking handlers are correctly triggered, the call to handleURL is returning false - I've verified the url…
