I'd like to rename the bars in my funnel analysis, but I cannot find the option to do so. Please let me know how I might be able to. I've attached a screenshot of the labels that run across the bottom of the chart.
Hey
You can try clicking on the event name on the graph’s X axis to customize the text labels in the bars as shown below.
Hi
If you have any further trouble, let me know and I can help!
Seems to be that on a long funnel which requires horizontal scrolling the functionality to rename is disabled.
Hi
For the one you can’t, which labels can you not edit? I can then investigate.
Hi
Here is an example (let me know if you can’t access the chart): https://app.eu.amplitude.com/analytics/coverwallet/chart/e-fxwaglri?linkingDashboardId=e-t3bhlzqm?source=copy+url
Thanks,
Diogo
