Overall total registered users per month
  • 23 November 2021
  • 142 views
Hello I want to create a bar chart in which I can see the overall registered users per month on my app .
Example : January :187 users , February 200 users .
I have an user id property and i can check the overall users right now but i didn't figure out how to group it by months and see the difference .
Best answer by Saish Redkar 23 November 2021, 16:37
Hey @tutyhulit,
You can create a chart like this to graph your users per month using the Stacked Bar View  - https://analytics.amplitude.com/demo/chart/new/reozee1
I have used the “Any Active Event” in this, but you can put in your registration event if that suits your use case better.
