New Registration on same device already registered with amplitude
  • 16 November 2021
  • 5 replies
  • 662 views
I am facing a bit of trouble while working on registration process of the app. The details are undermentioned.
If I am already registered on my app  through that particular device, it assign me an user id and amplitude id.
If I again try to register the new user via a same device, its not changing the user id and updated info is getting sync with already created user id.
Eg
Person 1
Event : Registration
User Property :
Mobile Number - 99889988xx
User Type Trader - Trader
User Id : 1234
When registering new person on the same mobile device
New User : Person 2
User Property :
Mobile Number - 72132882xxx
User Type Trader -  Farmer
User Id : 1234
Its syncing info with already created user id of old user on this app."
Best answer by Saish Redkar 17 November 2021, 02:44
Hey @sanchit
Is your implementation set up correctly to assign a new user id based on the new registration event?
In the 2nd case it seems like the user id for Person 2 is the same as Person 1 i.e 1234.
Here’s an article which explains the concept of Multiple user IDs on the same device really well.
HI @sanchit ,
Thanks for writing into the Amplitude community!
I agree with @Saish Redkar ! The implementation sounds like new users are being assigned the same user ID which would merge them to that user. If the new user registers, I would assign them a completely different User ID to avoid them being merged into user with the ID of 1234. The article Saish mentions is a good resource to go through this and see.
I hope that helps! Let us know if you need any more help!
The problem is new user is assigned user ID when the user complete the registration process,
I will give you the example
There are 3 screen process for registration
Screen 1 - Name
Screen 2 - Address
Screen 3 - Phone number
Person #1 complete the registration process and his details are as follows
Name = N1
Address = A1
Phone number = P1
User ID = U1
now he logout of the device and again this 3 step registration process starts
Person #2
Screen 1 - Name = N2
Screen 2 - Address = A2
so if the process is completed till here, amplitude update the User ID = U1 with
Name = N2
Address = A2
as new user ID is only created when the person completes the full registration process. Now we have wrong data of Person P1 in U1.
HI @sanchit ,
My understanding of this is that the user is being set a User ID U1 which already exists, and therefore Amplitude will assume it is the same user and merge it. Is there a reason you are assigning the same User ID to a new user? You would need to implement it so that a new User ID is given for the new users. I would look at your implementation and instead of assigning a new user with the same User ID of U1, I would wait til after the full registration and then assign a new user ID that does not exist in the system.
Does that make sense? Is there a reason you are assigning a user ID of U1 for every user who comes to register? Or is it only if they drop off at screen 2? In this case, you would need to examine your implementation and ensure that setting a user ID only occurs after the registration.
@Saish Redkar , thoughts?
Agree with Denis here.
It would be ideal that the user be anonymous till screen #3 and then once the registration event is completed, then only assign the user ID. You may have to test out this scenario and see which one plays out better in your use case.
