I am trying to create a segmentation chart where I filter out events in which two different event properties are equal; an equivalent SQL filter would be WHERE event_prop1 <> event_prop2. Is something like this possible?
Hey
Afaik, Amplitude currently doesn’t support direct comparison between different event properties on a given event. We can only use the comparison for the actual property values like event_prop1 = ‘stringABC”.
The closest thing possible which I have used to comparing two event properties in Amplitude in some context is the relative count feature in a cohort as follows. Not sure if this will help you in your case
Thanks
Hi
Does Amplitude still not support direct comparison between different event properties? I want to subtract one property value from another and see the difference, and I saw that this was an issue two years ago.
A workaround is using computed properties (if available) or creating a custom event with the comparison already applied. Another option is exporting the data and doing the comparison in a BI tool or database.
