How is "active" defined in Cohort definition?
  • 26 August 2021
  • 149 views
Userlevel 1
Badge +1
If I am adding a condition in cohort definition “The Users who ...had been ‘active’ during last 30 days”, does it mean the user had logged at least one event every day in the past 30 days?  Or does it mean the user had logged at least one event in the past 30 days?
Best answer by Saish Redkar 26 August 2021, 20:06
Hey @Bill
As per Amplitude, by default, an active user is a user who has logged at least one event during your selected interval of real-time (5 minutes), hourly, daily, weekly, or monthly.
Since you are creating a cohort, I would also point out to definitions of the options available under the anytime dropdown for added context.
Badge +3
Hi @Bill ! As usual, @Saish Redkar is totally correct :D
Being active during the last 30 days means that the user logged at least one active event in the last 30 days.
Note that all events are active by default, but you can set an event as inactive in Govern.
Let us know if you have any questions!
