How I can calculate average time between screen
  • 12 February 2023
  • 132 views
Hello.
Can you help me to understand how can I create onboarding time statistic per screen?
I need to understand average time that users spend per each screen in my onboarding flow.
For example: I have 5 screen on my onboarding. I need to know that average time on 1st screen will be 5min, 2nd screen 2 min, 3rd screen 15 min ...etc
Thanks
Best answer by tsegalla 13 February 2023, 16:56
Userlevel 3
Badge +5
Hi @Aleksei Beliatko,
If you have a way of identifying those separate screens via a combination of Events and Event Properties in Amplitude, you can view the average and/or median time to convert between each screen via our Funnel chart.  More info here.
I personally like using the data table at the bottom of a funnel chart to see the numbers between each step more easily.
I hope this helps!
Thank you @tsegalla! 😃
