How do you track custom url parameters through Amplitude?
  • 24 February 2023
  • 1259 views
We wish to track our own custom parameters.
For example:
In the case of a user entering the website for the first time through this url “test.com/home?utm_source=foo&ad_id=bar”
Amplitude would capture utm_source, which is “foo”, as his initial_utm_source. But wouldn’t capture ad_id=bar at all.
How can we setup Amplitude in a way that ad_id gets captured as well as initial_ad_id gets set.
Best answer by Saish Redkar 28 February 2023, 21:55
Thanks for this question @edwinsevlaraj. I found this thread with some additional details to help. Keep us posted as you make progress.
Hey @edwinsevlaraj
Here are the parameters which are supported via utm tracking
https://www.docs.developers.amplitude.com/data/sdks/marketing-analytics-browser/?h=utm#web-attribution
I’m not quite sure if you can map anyone of the above to your custom ad_id or use the Attribution API.
Another approach would be to extract this id using a derived property on your captured page url ( if you are capturing this one ) and use this for charting.
